| Had cat mechanic down to check why it pulls hard to the right. Found accumaltor on the left side low of course that didnt fix it. He noticed it didnt sound quite right when it started in which it just began doing. So #6 injector bad and set overhead it does start like it had now. But the steering is not fixed after two service calls found the steering valve underneath the cab but his internet didnt work so we did not know which set screw to turn. I figured out sitting still it steers more right then left at same steering wheel degree. Does anyone know which set screw to turn i count 5 possible. | |
