Posted 3/15/2012 10:02 (#2288418 - in reply to #2288137) Subject: Re: puting 7800 to 120" wide
SE SD
Just use your outside dual rims. We do this on a 4960 and a 9230 jd for pulling a pull type sprayer. If you are going to use the three point then I would use the cast centers on the main tires just flip them backwards and side for side. We've done this on the 4960 and had a 1250 gallon tank on the three point with no problem. Its a little work but it does work.
