Posted 3/14/2012 23:38 (#2287946 - in reply to #2287846) Subject: Re: Cat 55 Possible electrical issue
Walnut Grove MN USA
I found out on my 45 that you cannot shift the tractor if the dash is not installed. The dashes in these tractors do give problems and mine is on its way to Ag Express to check out a problem now with the hyd filter bypass warning going off all the time. Something to look into.
