| Just a question for you guys. How far are you roading your tractors? From what I understand about tracks on anything a good rule of thumb is the farther you go the slower you should run. The heat tends to build up. Any comments or observations? I have an MT845A also. I am changing the oil in mine and one side is noticeably darker than the other. My fields are in a 7 mile radius of the place and the oil was last changed when they did the reaction arm update about 600 hours ago. | |
