Monticello Ar | Spring ride trailers serviced this country far longer than air ride. Check ur load equalizers between the front and rear axel springs on each side. Make sure there not cracked. Also check where the spring rides against wear block at rear of back spring and front of front spring on each side. If these areas are badly worn or cracked u can either replace or take a thick piece of metal and weld it in for spring to ride against. I run a spring ride Tempte and have hauled some heavy loads a long ways with never an issue. Watch hitting rough railroad crossings to hard they will help break springs as fast as anything I know. | |
