Posted 3/5/2012 21:45 (#2270128 - in reply to #2269927) Subject: RE: 8640 JD clutch lube pressure alarm???
Eastern Ontario
IF I remember correctly, it is on top of the clutch housing. Take out the floor and you should find it. If I'm wrong, then it is either on the right side of the clutch housing or near the oil filter housing in the hinge area. How's that for narrowing it down?
