NW, OH (Wauseon) | It's easy but you need to get your trans oil up to 140 F before you do it. Cover your cooler up with cardboard. Then hold down the PROG key within ten seconds of starting the engine, use the up and down arrows to get to TRANS and hit PROG again, (that is like your enter key) then go to SETUP, then to CLUTCH CAL, then set your Rpms to 1200 and turn OFF the fan and A/C and don't touch the steering until u are done. Then the screen will say "shift to forward" and hit PROG again, u will go through C1, C3, C5, ODD, EVEN, LOW, MID, HIGH, REV, and MASTER clutch, after each one is done a star will appear on the screen next to the clutch that was just calibrated, along with the value in Mili-Amps. When u are all done, turn the key off to store the calibrations. I usually go into the TRANS VIEW screen, and go into VIEW CLUTCH before I run the calibration and write down all the old calibration values to see how much they changed, this may be helpful in the future. | |
