| You need to get the corrections to the 262, not the pro 600. Make sure you have a cable going from the serial port of the modem to port B of the 262. (P/N 115-0171-935). The 262 needs to be atleast 2.0 for firmware. Configure the modem to output CMR+ at 115k baud rate. Go into tthe RDI of the 262. Turn port C flow on. Make sure CMR is coming in at 115K at 8N1.
Also use these settings to get the best results.
GPS Config menu
System Masks – Elev 6
PDOP settings - Mask 99
RTK Config menu
RTK Position – Favor Avail
RTK Plus Mode – RTK+ (Reset)
RTK DOP Mask – 99 to fix
RTK DOP Mask – 99 when fixed | |
