North Central, South Dakota | Need some help finding a part number for a pro shaft setup with the electronic clutch for row command. It's an older 1770 conservation 16 row planter running max emerge plus row units with some xp updates it has the seed star monitor and it's running chain drive. What i want or would like to do is change over the chain drive to the pro shaft with the electronic shut offs but run like a agleader seedcommand system instead of changing the seedstart to something that will control the rows i think this is the best way to go but can't seem to find a part number that will convert the chain drive over to the pro drive with shut off in one kit.
I have to admit i'm new to the whole john deere planter stuff since i've only used other colors in the past. |
