Hoffman, IL | I would get parts from IH not real expensive. Be careful while you are working on it. On the lower end it is just a sleeve but beware you will need to keep everything in time and torque it back up. I always put a dowel in one of the holes and scratch a timing mark on outside of housing. On the top the seal kit is not bad either just make sure it is clean . Also be careful when you start it don't have a hold of steering wheel if somehting does go wrong it will spin VERY fast and lock up.(It happened when these were first designed has not happened in a while but why take a chance) | |
