Posted 2/17/2012 11:11 (#2234282 - in reply to #2234231) Subject: Re: Best method to locate battery drain.
mw
Negative, it will light up if you have a short.. it should not light up if everything is correct which is why pulling the shorted wire will turn the light off.
