| I have one now. As was already mentioned, it is non-live pto with built-in over-running clutch and live hydraulics. It is a 2 cylinder with 4 speeds in 3 ranges with diff-lock on rear wheels. Mine is also a FWA and will really pull for its weight/size. The engine is 26 hp and is quite economical to operate. The only drawback I have experienced is the radiator plugs easily with pollen/seeds when running a bush hog mower and has to be blown out. The tractor is not the most spacious workspace but is ok for 3-4 hours at a time. I can't say about the parts as I have only put on filters and a radiator hose in the 15 years I have owned it and I got them at the AGCO dealer (it was harder to find the dealer than the parts). I don't believe any had power steering so I don't know how a loader would be to use but the tractor steers easily when moving.
Al | |
