Posted 2/16/2012 17:05 (#2232673 - in reply to #2232582) Subject: Re: Tips for changing my trailer axles from a open center to hub piloted
Sac & Story county IA
If you decide it is easier to change axles. Torch the U bolts and buy new. They aren't to be used again and a ton of work to get them off in one piece.
The newer axles where you can put brake shoes and drums on without touching the bearings are a good improvement. As good as bearings and seals are anymore, a person can go the life of a trailer without looking at them.
