East Central Indiana | I've decided to go with an Eaton Polar air compressor since I'm only 45 miles from their factory. We don't do any sandblasting and minimal painting. Main air uses are impacts, grinders and cut off tools. Do I need the 80 gallon 5hp unit for our 60X80 shop or will a 60 gallon 5hp unit fit the bill? Using 3/4" Max line rapid air system for air lines through out the shop.
The 60 gallon unit is almost the same price as the the 80 gallon IR unit I was going to get from TSC. Seems the polar air is much higher quality, made in the USA, runs slower, and is only an hour from home. No brainer. | |
