| The performance monitor that you listed, that you need, will be the only way to fix the hitch system. It will list fault codes, be used to calibrate, and is used in diagnosis of operating problems, check sensor voltages and other readings. It comes with an extension harness that will hook up to a 4 pin plug located in your fuse panel area. Any dealer that has sold 6000, 6005, 6010, and 6015 series tractors will have this. There was a revision in calibration procedures when 6000's were fairly new but I am sure that it is updated in your new book. | |
