Southeast North Dakota | Is it the one in the Titan Machinery network? I just looked at it today......it needs work. The wiring is completely messed up, one light works and it only works with the switches in the "off" position. For some reason the guy has the wires off on the starter, and when you want to fire it up you have to attach the wires, and while it's running the ammeter is PEGGED past 16 which is not right. The hinge pins were loose, and the steering pins and bushings were SHOT, I could move the wheel quite a ways both ways and not get any steering, then finally it would start turning. It did run and shift nice, but it needs a lot of work.
Edited by Versatile Farmer 2/14/2012 22:05
