Thompson ND / Grand Forks ND | First one is some kind of European rig with French manuals originally. The codes definitely looked odd and when I pulled the customer history, the screen goes blank. Couldn't check warranty history either.
Base Machine Code:6815RW
Component Serial Numbers
Serial Number Component Invoice / Transfer Date
RG6081H052268 6081HF ENG 16Mar1998
RWSG052034284 SG BODY 16Mar1998
R0AG810034316 AXLE 16Mar1998
R0AH256068805 FW-DRIVE,M 16Mar1998
R0TD168040558 TRANS 16Mar1998
Build Codes
Code Description Invoice / Transfer Date
1110 16 SPEED PST. 30K 16Mar1998
2300 THREE REM CYLINDER CONTROLS 16Mar1998
2410 INDEPENDENT PTO-1000 RPM 16Mar1998
2555 RS W/HITCH(CAT3)SWAY BLOCKS 16Mar1998
2705 REGULAR DRAWBAR EEC 16Mar1998
2800 30.0GPM HYD.PUMP 16Mar1998
4288 2 CST-620/70R42 ** R1W (KL) 16Mar1998
6199 FRT-600/65R28 147A8**R1W-KL 16Mar1998
8020 SEAT, DELUXE 16Mar1998
8503 FRENCH OP MANUAL & LABELS 16Mar1998
9012 HYDRAULIC TRAILER BRAKE 16Mar1998
9022 TRUE GROUND SPEED RADAR SENS 16Mar1998
9031 VIDEO, PAL FORMAT 16Mar1998
9144 UPPER SIDE LIGHTS 16Mar1998
9196 CONVENIENCE PACKAGE 16Mar1998
9988 NO TIRE BRAND PREFERENCE 16Mar1998
Second one is one owner as far as Deere knows. One minor warranty claim.
PIN:
Process
Base Machine Code:6811RW
RG6081H036595 6081HF ENG 10Oct1997
RWSG052030474 SG BODY 10Oct1997
R0AG810030492 AXLE 10Oct1997
R0AH256061468 FW-DRIVE,M 10Oct1997
R0TD168036187 TRANS 10Oct1997
Build Codes
0989 SGB W/HTAR DELUXE 10Oct1997
2300 THREE REM CYLINDER CONTROLS 10Oct1997
2410 INDEPENDENT PTO-1000 RPM 10Oct1997
2530 RS W/HITCH(CAT3/3N)10400 LBS 10Oct1997
2800 30.0GPM HYD.PUMP 10Oct1997
3003 REAR AXLE (100MM) 118.5 IN 10Oct1997
4255 2 CST W/14.9R46 *** R1 10Oct1997
4955 2 STL W/14.9R46 *** R1 10Oct1997
5021 MECHAN. FRONT WHEEL AXLE 10Oct1997
6162 TWO 14.9R30 *** R1 10Oct1997
9016 FRONT FENDERS FOR MFWD 10Oct1997
9109 AM-FM STEREO RADIO 10Oct1997
9412 QUIK-TATCH WGT SUPT W/12 WTG 10Oct1997
9994 TITAN TIRES 10Oct1997
