Search Forums | Classifieds (73) | Skins | Language
PTO generator problem
mtbrights
Posted 2/3/2012 19:05 (#2203989)
Subject: PTO generator problem
Carter Montana
My 15KW Onan 15-OYD pto generator (1PH) is putting out under voltage at 540 RPM. It reads 39 volts on the 110 volt outlet. If I kick it up as high as 650 RPM or so I get 44-45 volts on the circuit. It does change with RPM and seems very stable. The voltmeter on it reads somewhat higher 20-25 volts than the 110 circuit. It's an 83' vintage and Im wondering if a new style regulator would be better than rebuilding the old one. 15 KW would be enough for me if would work properly. The parts are becoming obsolete and expensive.
Edited by mtbrights 2/3/2012 19:07
