| Although that sounds like a GREAT idea, i dont think it would work with out a decent amount of modification. Main concern i have is GPM. Foam marker does not take very much, and so i dont think the pump could put enough out. Second is, and i giess this goes with the first, but the compressor will not be able to substitute enough air pressure for the required gpm to get a nozzle to work very good, or at least that is my thinking.
Just curious though, why do you need a separate tank? Are you wanting to spray real deadly stuff on the fence row to kill everything, including the last row or so of crop? I guess for me, what ever im spraying on the crop, will do good enough on the fence row. | |
