Posted 1/30/2012 20:33 (#2195717 - in reply to #2195545) Subject: Re: bolts/nuts for salford RTS hubs
Hi
these are regular grade 5 bolts 1/2" x 2 1/2" and the nut is a 1/2" x13 NCstover lock nut
Any time you change a blade the lock nuts should be replaced with new ones as they will not be as strong on locking as the first time they go on.
You may lose blades if the nut is reused.
