Williamsburg, Iowa | Matt,
The scale system simply needs a 12 volt power source to the three pin weather pack connection using only white and black wires in the plug. The white wire gets 12 volts and of course the black wire is the ground wire. Once you attach power to the weather pack connector the scale junction box and remote display will power up. You will then be able to see weight for both tanks. If you have any other questions please let us know.
Thanks | |
