Posted 1/13/2012 23:06 (#2160720 - in reply to #2160555) Subject: RE: miller offset disk,good or bad?
North central SD
Good disk, quite a few around this area back in the 80's and 90's. Dad still does some seeding with his in the spring if ground is dry. Cut good, yet are easy pulling for an offset. Uses common type bearings, just make sure you keep the gang bolts tight and bearing hangers at a right angle to the gang.
