Posted 6/4/2006 15:36 (#16976 - in reply to #15851) Subject: RE: NH3 Coulter
no no no this set up will drive you crazy! if the residue is any where but all on top and the surface is not consistently hard and dry this set up will plug constantly the other factor is there is no beaver tail/sealer on the knife so nh3 will just blow back out use a clymer coulter/shank set up with a mole tooth best of luck
