Search Forums | Classifieds (124) | Skins | Language
ez-steer lite bar for spraying?
hwdcne
Posted 5/27/2006 22:28 (#15315 - in reply to #15293)
Subject: RE: ez-steer lite bar for spraying?
I understand you are using the EZ Steer, not the plus, correct? I am using this to spray with in row crop to find my right rows. Works fairly well, but if your rows aren't real accurate of course the light bar is going to read off also. In that case if you have an existing AB line, set it to do A+ and then everytime you come to the end of the field and the lightbar is off, hit the arrow and AB button, this will again get you back to where you need to be. If your rows are off a lot, this may need to be done every round. If they are accurate, you won't need to do it much. Using 110 receiver with all undates, I assume you are also.
