Posted 12/1/2011 10:41 (#2078618 - in reply to #2078134) Subject: Re: Banding fertilizer
Michigan - Saginaw County
The AgPhd guys do it using GPS to strip till and band, then spring plant directly over the center of the previous fall strip... Darren says his experiments show you need to plant within 5" laterally of your centerline... More than that and you start losing yield...
