Id agree that your mix will be fine ...................However.............. Assuming you have it in the booms too.......If your using ams (not sure if it or the Rup is the cultprit) Ya might want to fold out your booms and spray a couple gallons out before you hit the feild. For some reason we have had a "burnout" V pattern after the sprayer has sit for a couple days. Other than that, you should be just fine.
Edited by Newguy 5/27/2006 20:32
