Central Kansas | The biggest problem from Colwich is the consistency and availabilty of the product. Their moisture will run from 50% to 75%. The problem I had was you would contract it from them then if the price went up the no longer had it available but if you had your neighbor call in 30 seconds after you did they had all you needed on a spot price basis. I decided to no longer do buisness with them and use a plant that would stand by their contracts. | |
