Search Forums | Classifieds (90) | Skins | Language
Grazing Rye
Jim
Posted 9/4/2011 22:07 (#1946616 - in reply to #1946592)
Subject: RE: Grazing Rye
Driftless SW Wisconsin
I used a drill to plant some rye a few years ago and had a good stand.  The problem with broadcasting the seed on hard dry ground as you describe, even with a rain the seed may or may not get some soil covering it.
I would use a drill.  Or if you want to broadcast, at least pull some sort of drag over it after broadcasting. I have had some good stands pulling a Wingfield harrow over broadcast seed when I am trying to get some cover on a winter sacrifice area etc.  Not as good as a drill but better than not doing anything to incorporate/cover the seed. jmho.
Good luck.
Jim at Dawn
