roaming | Yes, the IntelliView Plus monitor is black-and-white; it is essentially the same as the newer CaseIH Universal Display Plus monitors.
To my knowledge, there is no way to connect the Insight monitor to the existing NH y&m sensors, so you would need a complete AgLeader sensor kit.
Whatever you do, I would NOT recommend the existing Infoview monitor and data logger. BUT, if you do decide to stay with it, you'll need to have the latest software to be able to read your data into Farmworks. The original data logger format cannot be read by Farmworks, IIRC. The newer data format is the same as the format used by the Intelliview Plus. | |
