NW Iowa | It is late enough that there is no point in spraying. Not a whole lot of info out there for treating aphids late in the season. I would say if you were only at 50% dented and had a lot of aphids above the ear, then you might see an effect of spraying. At 50% milkline, yield is virtually made. Some sprayed around here a couple weeks ago. Didn't personally spray any but had spots with some heavy pressure. |
