Little River, TX | Thanks to our friends up in Oklahoma, & their News Letter. What is the value of nutrients in baled corn stalks? The hot and dry weather this summer has had devastating impact on all dry land crops. Many acres of corn and soybean are not going to make it, so many growers are baling or considering baling corn stalks for hay. Some drought stressed corn may be harvested for silage also. However, we need to remember that there is a value to leaving the crop on the ground as a nutrient source for the next crop and as organic matter for long-term soil quality, which is always beneficial. Crop residues contain all plant essential nutrients, especially N, P and K. Baling stover for hay or for sale will remove those nutrients from the field. So, can we put a value on the baled corn stalks? We can calculate the main nutrient value based on the nutrient content of the residue and current market prices for N, P and K. The table below shows the estimated N, P and K value of baled corn stalks for two different moisture contents. The nutrient contents are average values and they vary with growth stage when harvested and with soil fertility levels. Using current nutrient costs, the baled corn is worth nearly $40/per ton on a dry weight basis. The value drops to $15/ton if the stalks have 60% moisture. Note that this is just the value of the nutrients themselves, and the potential value would be higher if fertilizer application cost is factored in. Estimated nutrient value of baled corn stalks. Moisture Total N P2O5 K2O N, P and K value % lbs/ton $/ton* Dry Basis 0 24 8 32 37.6 As Harvested 60 9.6 3.2 12.8 15.04 * Estimate based on $0.6/lb of N, $0.5 lb of P2O5, and $0.6/lb of K2O If the crop residues are left in the field, all nutrients and organic matter would be returned to the soil. However, not all the nutrients are going to be available to the following crop because organic matter must be decomposed before nutrients become available. Conservative estimates suggest at least 60% of N and 80% of P and K will be available for the next crop. Consider the nutrient value and organic benefits when baling a failed corn crop. Hailin Zhang Hailin. |
