Both sides of the Mason-Dixon Line | the area number is a calculation of swath width*distance traveled so there's several things to check. Make sure that your swath is setup correctly. Next, make sure that the monitor is set to the ground speed signal provider that you are using (wheel, gps, radar ) and that its calibrated. Finally set the stop height so that the monitor shows "area on" when you are harvesting. Also make sure that the manual area on/off switch in the lower right corner is in the on position. If you have specific questions on where to find all of these settings call ag Leader at 515-232-5363 ext. 1. |
