West Union, IOWA FLOLO Farm 52175 | On big bales.... you gotta pour it down the "spear hole"
I've done big rounds or big squares.... works great, but you have to cover or it just gets outside humidity.
On rounds-- set the bale one end/beercan .... as you pull the spear wiggle it to widen...and then pour a coffee can of salt down the hole
Big squares-- I'd jus pour a coffee can full down the center of each bale, and the set one on top....til 6 high....don't worry about the top one.
Seen hay that should never have been baled keep and look great doing it--- way better then Proponic acid. |
