Eastern VA. No such thing as too many Magnums. | I agree with the other guys, raising the RPM a little is normal to make booms function with the solution pump running. It also depends how you have the "boom off" pressure set, and whether you're running agitation or not. If I'm running agitation and have the boom off pressure set to 50 psi, it probably takes about 1300 to fold or raise the booms. It works fine if the oil is cold. But hot oil requires a little RPM. |
