| Take the pounds of active of each ingredient in a gallon and convert to the number of pounds of that active you are applying in a 3.6 pint per acre rate. Halex has 0.209 pounds of Mesotrione (Callisto) in a gallon, so if you apply 3.6 pints/acre you would apply 0.094 pounds of Mesotrione. Callisto contains 4 pounds of Mesotrione per gallon. So you then take the 0.094 pounds of Mesotrione in 3.6 pints of Halex divided by 4 pounds in a gallon of Callisto to convert to the percentage of a gallon of Callisto you get in 3.6 pints of Halex. Then multiply that percentage of a gallon by 128 to get to the number of ounces of Callisto contained in 3.6 pints of Halex, which is 3.01. You do the same for the Dual and Touchdown. Grad school was good for something! | |
