central - east central Minnesota - | CaseIHpride - 6/15/2011 12:34 What would you guys do to prepare ground that was rye since November for planting? It was grazed heavily since November and had manure applied on it in that time frame. We disked it once and then ran a case ih 330 turbo till over it. It worked up pretty good but i wish we could just plant right into it. Thanks for your inputs.
Why can't you plant into it? Plant what into it? In the sand, the 'tator farmers spray with RR and plant into it . . . . But, as Ed posted - if it needs some tillage, the Turbo till should be enough - based on the info you provided. |
