West Central WI | Frothy "feedlot" bloat maybe?
"Frothy bloat also is seen in feedlot cattle, and less commonly in dairy cattle, on high-grain diets. The cause of the foam in feedlot bloat is uncertain but is thought to be either the production of insoluble slime by certain species of rumen bacteria in cattle fed high-carbohydrate diets or the entrapment of the gases of fermentation by the fine particle size of ground feed. Fine particulate matter, such as in finely ground grain, can markedly affect foam stability as can a low roughage intake. Feedlot bloat is most common in cattle that have been on a grain diet for 1-2 mo. This timing may be due to the increase in the level of grain feeding or to the time it takes for the slime-producing rumen bacteria to proliferate to large enough numbers." | |
