Posted 6/13/2011 00:08 (#1816362 - in reply to #1816181) Subject: Re: Polaris Ranger?
nc ia
I have 1-1/2 " off set rims plus 1-1/2" spacers on front and 2-1/2" spacers on back. Center to center is 58" which is close enough to 60" Any wider will put a lot more pressure on bearings and its not needed because you will lose clearance under the frame before the tires get close to the rows.
