Cat MT 745 3 point problem
dutch
Posted 6/10/2011 19:21 (#1812982)
Subject: Cat MT 745 3 point problem
West Texas
3 Point will not go down from inside the cab using eitther the switch or the manual lever. Goes up and down fine with the fender switch.
Also the dial control on the display isn't working correctly. When you want the 3 pont settings it goes to the hitch steering page and when you want the transmission set up page it goes tot he PTO setup page. Have to hold the dial just right for it to work......if you're lucky.
Related problems with the console or something else? Tractor has 3000 somewhat hrs.
Thanks.
