| I use one. The most important thing is your bale itself. They need to be uniform in length and density, The bales need to be very solid. If you have good bales, they work well. If you don't, they can be a nightmare. You also need a level area for stacking. If you get a 1002, make sure you get the operators manual for it. Once you get thru a short learning curve, they are easy to use. | |
