| We have a set of 710 x38 Titans on our 400 hp four wheel drive they were installed ten years ago ,,, i love them,,,, still have about 85% tread we keep the pressures at 14 psi rear and 16 psi front weighs 40000 lbs they have hard rubber and dont wear easily ,,,,, having said that they cannot be run with low pressure like was recommended in the early days of big radials or the sidewalls will get destroyed because the sidewalls are stiff,,,, would not hesitate to buy another set when needed | |
