Person County NC | I have a belt driven spreader that has started acting up every once in a while. The belt will stop occasionally. The drive tire was a little slack, pumped it up but that didn't fix it. The belt is getting pretty slack and is tight as it can be without removing a link or putting washers under the adjustment bolts. I have no idea how to take a link of the belt, or if that is an option.
Anyone with more experience than me with these things? Is the loose belt likely the problem? | |
