Posted 6/1/2011 13:45 (#1801803 - in reply to #1801738) Subject: RE: Maxxum 125 in cab power
S.E. Iowa
Our NH 130 the power plug in the cab is a 30amp circut. Look at your monitor and see if their is an inline fuse power requirements wont need to exceed the fuse. I know our planter monitor has a 3 amp fuse and our JD baler monitor uses a 15amp inline fuse so you should be good. Check your tractors manual to be sure.
