NC ND | Been using this for years as the controller, I haven't run it in quite a while. Discovered that radar in tractor was reading 1 mph slow. Hooked the gps up for speed sensor, speed in Raven was quite low, so I played around with the speed calibration number until it matched the gps unit.
Should I have done this? is appears that after one tank the acres on the raven are reading higher than the what the gps is getting by about 15 acres in 50 acres worth. Or am I completely missing the problem and it is somewhere else.
Did run the tank right out so the rate was starting to bounce a little with vapor, that will screw up the acres some also won't it. Am I right that the gps acres should be the most accurate? It was reading acres from when I clicked the autosteer on and I did no headlands, the whole tank was done by autosteer.
calibration number went from the original 820 to 1350 to get the speeds to match.
Edited by runningbehind 5/29/2011 08:18
