Search Forums | Classifieds (35) | Skins | Language
Integra and seed command( HELP)
panotiller
Posted 5/25/2011 23:51 (#1792376)
Subject: Integra and seed command( HELP)
Lewisburg, PA
Corn planter sat for two weeks of and on in the rain. Wen tto the field tonight it wouldn't finish set up it would keep coming up with row clutch module doesn't match the configurations ,check configuration or check wiring. Well I have some corrosion in the big twist lock between tractor and planter I messed with that for a awhile cleaned it up a little. Then it worked once would finally complete the field det up to the run screen. Then I changed thefarm now we are the back to square one.
Edited by panotiller 5/25/2011 23:51
