Near Intersection of I-35 & I-90 Southern Mn. | I believe he means that the EZ-Guide 500 is not always available and needs to be able revert to using the original controller without EZ-Guide being present.
If EZ-Boom is going to be used for section control, the wiring from the original switches needs to be diverted so that EZ-Boom can control the boom sections and also inform the Deere controller as to which booms are ON so that the Deere system can control the rate.
This means that the EZ-Boom Master and Boom switches would normally be used and the Deere Master button would be turned ON and left ON. EZ-Boom would control the sections and the Deere will adjust the rate properly. When approaching an end, autoswath will shut off the appropriate sections and the EZ-Boom Master switch would be used to prevent any surprises. The Deere Master Switch button would be left ON.
The Master Swtich button will cycle to OFF when the pump is shut down, so the operator needs to remember to reengage it to start spraying again.
Edited by tedbear 5/23/2011 14:51
