North West Missouri | ok guys , I lowered the antenna height from 112.25 to 82.25 that helped a little, I also set it back to 19200 and 5 had it on 38400 and 10, my antenna is centered above rear axle so offset was already 0, should I move antenna closer to the front of the cab? my settings are 10 and 10 on first page and 10 ,9 and 10 on second page. good smooth going , its flawless , a little roll or roughness I get some wiggles. the ecu is NOT moveing and I do have the updated firmware........Thanks for all the previous suggestions much appreciated !..how low can I set the antenna height and not effect accuracy ? | |
