Near Intersection of I-35 & I-90 Southern Mn. | frytownfarmer - 5/20/2011 16:33
Or to my ez-guide 500 or will it work by itself. I bought an 854 and it had a 661 in it. I wanted GPS so I put a ez guide in it and to save space took out the raven. Left in the side kick and now want to get the side kick running. Book shows it plugged into a raven. Is my ez guide compatible? Thanks
Not quite following you. The Ez-Guide 500 could work with EZ-Boom for the main product rate control. Then the Sidekick could be tee'd in like it was with the 661. Without a 661 or EZ-Boom you wouldn't have any control for the carrier.
If the carrier is delivered by another source such as a ground driven pump, the Sidekick can be turned ON/OFF by other means. I need more information.
Edited by tedbear 5/21/2011 08:56
