Southwest Ontario | Set at 120 right now but doesnt change anything on the line aquisition when you change that parameter.Only thing that makes any diff. Is when you change the antenna offset in the gps setup page I believe.When you lower it to about 12 " it will turn in much better but not good enough for standing row crops like my 4710 deere will. This also causes problems with the start early and stop lates. | |
