E Central Ar | I build mine with one end wall and have side metal down at least 6 ft that keeps the water that run off the roof from blowing in
I also like for the roof to extend 1 ft wider than the side walls
I have found that helps alot
I always build a level pad and then build the barn. that way I can get drainage all the way around usually start with 12 inches above the highest point and work from there
then I add a minnimum of 6"s of rock on the inside and I never have a water problem | |
